Date/Time: Sat, 23 Nov 2024 02:18:07 +0000
Change in quantity on the line when chart trading
View Count: 102
[2024-09-13 15:33:47] |
User43540 - Posts: 7 |
When changing the quantity (limit order, stop order) directly on the line on the chart, the "overwrite mode" was set earlier (e.g. in v. 2634) (by entering a number from the keyboard the current quantity was overwritten). In the last few versions, however, the "insert mode" is already set (new quantity is added before the current one - e.g. changing from 2 to 4 results in 42). Can this be set somewhere or is it a bug in the new version?
[2024-09-13 15:47:18] |
In order to have the quantity automatically selected when you go to change it, set the following option to "Yes": General Settings Window: Select All Text in Edit Control Upon Editing (Global Settings >> General Settings >> SettingsWindows) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
