Date/Time: Thu, 02 Jul 2026 09:58:24 +0000
[Programming Help] - ASCIL Trailing Stops Question
View Count: 666
[2024-09-13 13:18:35]
User371315 - Posts: 10
I'm trying to figure out the best way to approach this in ASCIL.
Use Case: I have a trailing stopoffset of 8 points and when the contract profit reaches $500.0, I want the stopoffset to be 4 points.
Whats the best way to handle it? Should I use triggered trailing step stop loss? Or write something myself to just update the stopoffset of the current stop order?
[2024-09-17 00:57:38]
ForgivingComputers.com - Posts: 1231
int MoveStop(SCStudyInterfaceRef sc, const int OrderID, const double SetStopPrice)
  // Look Up Stop Order to see if Open EXIT if not result = -1
  s_SCTradeOrder TradeOrder;
  sc.GetOrderByOrderID(OrderID, TradeOrder);
  if (TradeOrder.OrderStatusCode != SCT_OSC_OPEN)
    return -1;
  // Look Up Previous Stop Price
  double PrevStop = TradeOrder.Price1;
  double NewStop = sc.RoundToTickSize(SetStopPrice, sc.TickSize);
  int result = 0;
  // Compare To SetStopPrice if Equal Result = 0
  if (PrevStop == NewStop)
    return 0;
    // // Create ModifyOrder
    s_SCNewOrder ModifyOrder;
    ModifyOrder.InternalOrderID = OrderID;
    ModifyOrder.Price1 = NewStop;
    result = sc.ModifyOrder(ModifyOrder);
    return result;
