Date/Time: Thu, 31 Oct 2024 10:13:00 +0000
Formula modification
View Count: 178
[2024-09-13 10:25:18] |
User333599 - Posts: 7 |
Hello, Could you please help me modify Formula Type 27, Pivot Point (PP)=Current Open, to Pivot Point (PP) = (Prior High + Prior Low + Prior Close)/3 ,in the Formula Types? I look forward to your reply. Date Time Of Last Edit: 2024-09-13 10:27:16
[2024-09-13 15:23:39] |
John - SC Support - Posts: 35639 |
We can not change an existing Pivot Point calculation. There are others that use the Pivot Points study as it is and rely on it to stay the same. Since there are other Pivot Points options that do calculate what you want, you can use a combination of two Pivot Points studies to get the main Pivot Point from one and the other Support/Resistance lines from the other study. Just set the subgraphs you do not want to "Ignore". Refer to the following: Chart Studies: Ignore (ACSIL: DRAWSTYLE_IGNORE) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-15 15:56:55] |
Hello, I tried to modify the formula (Formula Type 15 (Fibonacci Zone Pivots)) in Excel but failed. Could you please help me add 0.236, 0.382, 0.5, 0.618, 0.786, 1.0, 1.382, 1.618, 2.0 to the chart in Excel? Thank you very much. |
[2024-09-16 15:00:30] |
We do not understand what you are trying to do. And we certainly can not help with Excel. Look at the Spreadsheet Study we have and see if you can do what you are wanting through that: Using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-16 16:36:39] |
I am inquiring whether it is feasible to incorporate (Resistance Level 1 (R1) = Pivot Point + Daily Range / 2) into (Formula Type 26).
[2024-09-16 18:59:36] |
As we stated previously, we can not change the existing levels for the Pivot Points study.
