Date/Time: Fri, 18 Sep 2026 07:20:43 +0000
Help: Mimic trading window multiple targets with stops in spreadsheet for trading
View Count: 568
| [2024-09-13 02:09:39] |
| User484096 - Posts: 20 |
I need help with spreadsheet for trading to mimic the trade windows 3 targets with stop. The target part is fine. It is the stop. It only close 1 part of the trade instead of exiting the trade. The Exit column turned 1 and stay as 1. J26: =IF(ABS(J8) = 3, 1, IF(ABS(J8) = 2, 1, IF(ABS(J8) = 1, 1, 0))) Target 1: 1/2 ATR Target 2: 1 ATR Target 3: 2 ATR Stop: 1 ATR If Target 1 is hit, move stop to 1/2 ATR If Target 2 is hit, move stop to +2 point or trail by previous bar. The underlined is the stop logic. Buy Exit: =OR(AND($J$8 = 3, OR(ID0.SG4@3 > ($J$9 + ID9.SG1@4 * 0.5), ID0.SG4@3 < $J$9 - ID9.SG1@4)), AND($J$8 = 2, OR(ID0.SG4@3 > $J$9 + ID9.SG1@4, ID0.SG4@3 < ($J$9 - ID9.SG1@4 * 0.5))), AND($J$8 = 1, OR(ID0.SG4@3 > ($J$9 + ID9.SG1@4 * 2), MAX(ID0.SG4@3 < ($J$9 + 2), ID0.SG4@3 < ID0.SG3@4))) ) Sell Exit: =OR(AND($J$8 = -3, OR(ID0.SG4@3 < ($J$9 - ID9.SG1@4 * 0.5), ID0.SG4@3 > $J$9 + ID9.SG1@4)), AND($J$8 = -2, OR(ID0.SG4@3 < $J$9 - ID9.SG1@4, ID0.SG4@3 >($J$9 + ID9.SG1@4 * 0.5 ))), AND($J$8 = -1, OR(ID0.SG4@3 < ($J$9 -ID9.SG1@4 * 2), MIN(ID0.SG4@3 > ($J$9 - 2), ID0.SG4@3 > ID0.SG2@4))) ) |
| [2024-09-13 14:03:45] |
| John - SC Support - Posts: 47930 |
Your Order Quantity (cell J26) is always set to a value of 1. So when the Exit conditions are met, it will only close out a quantity of 1. You would need to add logic to your Order Quantity to make sure the quantity is at least the size of the order quantity should your stop conditions be met.
| [2024-09-13 17:17:28] |
| Sawtooth - Posts: 4354 |
You could use J82/J83 for your exit quantity, referencing J8 for the exit quantity. When J82 is set to 1, J26 becomes only the entry quantity. Spreadsheet Systems, Alerts and Automated Trading: Use Separate Exit Order Quantity (write-only) [v1:J82, v2:J70] |
