Date/Time: Sat, 23 Nov 2024 02:21:00 +0000
Subgraph drawing
View Count: 121
[2024-09-13 01:12:05] |
User14953 - Posts: 235 |
If an alert condition occured at the close of the 10:00 bar can a subgraph drawing be displayed over the the bar prior to the 10:00 bar? |
[2024-09-13 13:50:29] |
You can do this by using the "Color Bar Based on Alert Condition" study and using the same Alert Condition in the study and then set the Displacement for the subgraph to be -1. Refer to the following, particularly the section on "Drawing Arrows/Text or Other Styles at the High or Low of Bars": Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
