Date/Time: Sat, 23 Nov 2024 02:10:46 +0000
Latest version bug
View Count: 188
[2024-09-12 20:47:06] |
User953554 - Posts: 9 |
Hi Support, just to let you know the latest release has an issue where the settings menu of the quote board doesn't display correctly [just a tiny grid ]. Usually on the first click after opening a new quote board is OK , then after its not good . i selected install previous version and all is back as it should be . I tried the update again and the same issue was there so i don't think it's my setup. I Reverted to previous version and all is good again. not sure the revision number but it's the one that get downloaded from the 'help/download current version'. Cheers |
[2024-09-12 21:25:55] |
Sierra_Chart Engineering - Posts: 17145 |
We apologize for this. We are looking into this.
[2024-09-13 00:43:08] |
user_xyz - Posts: 416 |
I see this on v2674
[2024-09-13 16:16:22] |
This is now resolved. Update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
