Date/Time: Fri, 25 Sep 2026 17:38:38 +0000
Remove study from value area window
View Count: 598
[2024-09-12 19:48:24]
User315753 - Posts: 27
Hello Sierra chart team,
I am looking to remove some studies from the value window from my chart. I tried going into the study and removing the ticks for the study being in the window and have not been successful in doing so. I know how to remove the default entries of the value window from chart settings but I do not know how to remove my studies that show up in the value window. Please advise.
Thanks.
[2024-09-12 20:41:23]
John - SC Support - Posts: 48019
The quickest way is to deselect (make sure there is NO checkmark) the option for "Display Study Subgraphs Name and Value" on the Subgraphs tab of the studies you do not want to show in the Chart/Tool Values Windows. If you also want to remove the Study Name in the windows, then deselect the option for "Display Study Name". Refer to the following and the 2 items below it):
Chart Studies: Subgraphs Tab >> Display Study Subgraphs Name and Value - Global
If you only want to turn off some subgraphs, then you would deselect the option for "Display Name and Value in Chart Values Windows" for each subgraph you want to not display. You would have to go through each subgraph and turn this off. Refer to the following:
Chart Studies: Subgraphs Tab >> Display Name and Value in Chart Values Windows
If you always want the way you setup a study to be the way it will show up every time, then you will want to have it setup and then select the option for "Save Defaults". Refer to the following:
Chart Studies: Using Custom Default Study Settings
[2024-09-15 01:57:45]
thank you
