Date/Time: Sat, 23 Nov 2024 02:15:40 +0000
Chart Trading Order Line Cursor Now Defaults to In Front of Numbers
View Count: 77
[2024-09-12 15:32:07]
User261655 - Posts: 28
When editing order quantity from a chart trading order line, the cursor now defaults to in front of the existing number, rather than behind that number, as was the previous default.
Previously, opening the edit order window looked like this:
5|
Now it looks like this:
|5
Not a huge deal, except that I keep forgetting that this behavior has changed and I need to perform more keystrokes before editing an order.
Just noting this in case the change was unintentional.
[2024-09-12 17:25:45]
Refer to the following setting that will have the value selected automatically, so you can then just type in the new value:
General Settings Window: Select All Text in Edit Control Upon Editing (Global Settings >> General Settings >> SettingsWindows)
