Date/Time: Wed, 11 Nov 2026 03:13:06 +0000
What are the changes from 2675 to 2676
View Count: 774
[2024-09-12 15:27:49]
User719512 - Posts: 536
There are some other threads that mention freezing in 2675. I also saw hard hangs in 2675 with a chart book that worked perfectly all day long in 2674 and lower versions. Load 2675 and within 10 seconds, Sierra would hard hang and the UI would stop updating. The menus and close button were unresponsive as if the Windows message pump was no longer processing events. Had to use task manager to terminate the Sierra process. 100% repro in 2675 with hard hangs. Running under the debugger with 2675 never showed any exceptions being thrown either.
Just tested with 2676 and am not seeing the issues anymore.
Can you please elaborate on what changes you made from 2675 to 2676?
[2024-09-12 20:49:04]
RobJ - Posts: 7
I'm seeing similar things. 2674: no issues, 2675: Freezing/unresponsive at times, especially when looping through s_ACSTrade structure after a long replay (2000+ trades), 2676: no issues so far
[2024-09-13 15:42:18]
Sierra_Chart Engineering - Posts: 25411
For information about this, refer to:
https://www.sierrachart.com/SupportBoard.php?PostID=394194#P394194
The problem will be resolved by increasing the Chart Update Interval.
In the latest release, 2677, we have reverted this change for now.
