Date/Time: Sat, 23 Nov 2024 03:02:52 +0000
Display first 5 level of market depth on number bars
View Count: 127
[2024-09-12 15:01:25] |
User887126 - Posts: 66 |
Hello SC team, I use number bars and want to see the first 5 level of market depth (both bid and ask side) on top of the number bars. i am not interested seeing all levels but just want to see 10 levels of depth (5 on inside bid and 5 on inside ask). i want to see stats (ex: added/pull bid, median bid size, etc.) related only to these 10 levels please advise how i can achieve that. |
[2024-09-12 16:55:13] |
We are not sure exactly what you are looking for in terms of displaying the 5 levels on top of the Numbers Bars, or in terms of getting stats on these. There is not a way to show the actual levels themselves, but you could show the sum of these levels, or various other items, by using the "Bid and Ask Depth Bars" study and then using the "Study Subgraph Above/Below Bar as Text". Refer to the following: Bid & Ask Depth Bars Study Subgraph Above/Below Bar as Text Note that you can control the number of levels that are used by the Bid and Ask Depth Bars with the following setting: Chart Settings: Number of Levels for Bid/Ask Depth Calculations (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
