Date/Time: Sat, 23 Nov 2024 01:52:07 +0000
Programmatic selection of trade service?
View Count: 129
[2024-09-12 09:33:46]
Danijel7504 - Posts: 2
Hi guys,
I'm trying to programmatically (ACSIL/command line/whatever works) select a trade service when starting SierraChart.
The according command line parameter (/service:) does not seem to work. No matter what I use there (e.g. /service:rithmic_v2.trading), it always starts up with the service I used before (e.g. Teton Paper).
I know it's possible to duplicate SC folders and have each instance have different connection settings - but I don't want that in order not to lose all chart data/etc. All I want is to startup SC (run _64.exe) with a DTS Config Preset of my choice.
Is there any way to accomplish this? Checked all documentation and couldn't find a solution so far. Where does SC store the currently selected DTS Config?
Thanks!
-Dan
[2024-09-13 16:50:35]
Sierra_Chart Engineering - Posts: 17145
There is no longer a way to change the Service from the command line. However, we will see about adding an ACSIL function to change the Data/Trading service.
[2024-09-13 18:52:08]
That would be awesome. Thanks! Any idea when that could become available?
