Date/Time: Fri, 22 Nov 2024 21:09:30 +0000
Make x axis and y axis smaller
View Count: 189
[2024-09-12 09:26:49] |
Jimmyy - Posts: 221 |
Is it possible to make the x axis and y axis smaller ? I tried to lower the font but that just lowered the font of the text and didnt make the axis smaller. Also is it possible to make the tiles border thinner where there are multiple charts tiled (check screenshot, marked in blue) Date Time Of Last Edit: 2024-09-12 09:30:15
Private File |
[2024-09-12 12:36:07] |
Sierra_Chart Engineering - Posts: 17145 |
You do need to adjust the font size and then after that select Chart >> Reload and Recalculate. For the other question, this is controlled by the operating system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-23 04:27:49] |
is it possible to set the date range from and to in all charts in a chartbook by entering it just once instead of entering it in every chart ? I have 15 charts in a chartbook and using it for bar replay so ... |
[2024-09-23 14:40:48] |
John - SC Support - Posts: 36236 |
You can use Chart Linking for this. Refer to the following: Chart Settings: Chart Linking >> Days to Load (Chart >> Chart Settings >> Linking menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-24 07:32:07] |
I was wasting so much time, I thought what i requested probably would sound dumb. you guys never fail to amaze me
[2024-09-24 14:12:49] |
is it possible to minimize all chart windows (including the ones that are detached and put on another monitor) when I minimize the main SC window?
[2024-09-24 14:43:22] |
Refer to the following setting: General Settings Window: Minimize / Restore Detached Windows With Main Window (Global Settings >> General Settings >> GUI >> Application GUI) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-25 15:18:22] |
is it also possible for charts with same linking to also jump to go to date time on all charts ?
[2024-09-25 15:28:01] |
There is an option for "Scroll Position" with the linking. Refer to the following: Chart Settings: Chart Linking >> Scroll Position (Chart >> Chart Settings >> Linking menu) But also be aware of the option for "Synchronize Charts" when using the crosshairs: Chart Drawing Tools: Synchronize Charts (Tools >> Synchronize Charts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-25 15:34:34] |
not quite what i want, just want all the charts to go to date time. possible to implement?
[2024-09-25 17:19:46] |
Also, is it possible to bring the NDX feed back? dont know why you guys had to remove it. for just one ticker i have to use another shitty platform :/
[2024-09-25 21:21:35] |
If you want all the charts to show the same time all the time, then use the linking option for "Scroll Position". We do not have a way to have all the charts move to a specific date-time one time only. We do not expect to bring back data for NDX. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
