Date/Time: Sat, 23 Nov 2024 02:40:08 +0000
Data/Trade Service Setting issue - PWD Show is not functioning as other installs.
View Count: 111
[2024-09-11 18:17:50]
User92573 - Posts: 530
Dear Support
I have downloaded an setup a new installation of SC as I want to change the chart defaults etc.
The issue is that on entering everything as per other installations when I go to Data/Trade Service Settings and enter Sever List + Trading Username all is fine ... that is until I try and enter the Password Manually as instructed.
The password and DTC login are not accepted by the server but that aside the 'SHOW' button does not show the Password. Just the asterisks.
Any thoughts appreciated.
Many thanks
Additional. I also not the Sierra4.config has not copied the settings as expected from the chart group and charts I copied from the other installation. They do not replicate or resemble the layout and configuration from the donor installation and the toolbars are all over the place. Not sure what's going on as the different global graphic settings / chart graphics in the other installations should be in the Sierra4.config and individual charts .. I thought?
Date Time Of Last Edit: 2024-09-11 18:30:58
[2024-09-11 18:41:34]
We will have to take care of the Password Show/Hide option. We do not know how this got changed to acting like it is.
The Sierra4.config file is the correct file for your global configuration settings. Keep in mind that items could be in different locations due to differences in the screen resolutions between the systems. And also consider that some charts could be set to use Chart Graphics settings instead of the global settings, but those should be showing as you would expect.
