Date/Time: Sat, 23 Nov 2024 02:29:18 +0000
Fake order keep opening
View Count: 128
[2024-09-11 16:11:42] |
User430992 - Posts: 1 |
Hello, I trade with Phidias Propfirm using Rithmic, and yesterday I encountered a serious issue with Sierra Chart. It started placing trades that I never made, resulting in a loss of over $1200. The problem persists, with "fake" trades appearing. When I place a trade, it behaves as if I’m closing another, and when I try to close the one I actually opened, it shows a new trade being opened unexpectedly. This is causing significant confusion and loss. |
Attachment Deleted. imag2e.png / V - Attached On 2024-09-11 16:11:36 UTC - Size: 4.7 KB - 30 views |
[2024-09-11 17:27:51] |
Refer to the following: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
