Date/Time: Sat, 23 Nov 2024 02:58:39 +0000
2 accounts
View Count: 136
[2024-09-11 15:51:05] |
SafSaf - Posts: 89 |
hello lads. i am with amp global and i've obtained another account with them. how do i add the account to my trading platform please?
[2024-09-11 17:22:21] |
What order routing service are you using with AMP?
[2024-09-12 09:05:57] |
cqg
[2024-09-12 09:22:23] |
it would be nice if all 4 accounts (which includes the sub accounts) were included in the drop down box in the trade panel?
[2024-09-12 15:09:52] |
If the other accounts you have with AMP are setup to be accessible through the same connection to CQG, then you should be seeing all the trade accounts in the "Trade Account" drop down on the Trade Window - as you state. In which case, you change between accounts by selecting the account you want in that list. Refer to the following: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Otherwise, if you were given different CQG credentials for each account, then these are completely separate accounts and you would need to have separate installations of Sierra Chart in order to access each one. The only issue with this is that you state you have 4 accounts. You can get the data from our Denali Exchange Data Feed to 3 different installations of Sierra Chart on the same system. But you can not do this for four of them. A solution would be to use a second computer, but you would have to pay a second set of exchange fees in this case. Refer to the following: Denali Exchange Data Feed: Connections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
