Date/Time: Sat, 23 Nov 2024 02:54:43 +0000
The Configuration File Might be Corrupt
View Count: 116
[2024-09-11 15:10:01] |
Alex C Demosthenes - Posts: 50 |
I'm getting an error "The configuration file size of 0 bytes is not the 617899 expected bytes to write. The configuration file might be corrupt." This is causing my charts to display just one single candle with a wildly fluctuating price. |
[2024-09-11 17:11:25] |
Please restore a backup copy of your Configuration file to resolve this issue. Follow these instructions: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-11 17:25:34] |
Thanks! This worked
