Date/Time: Sat, 23 Nov 2024 02:30:35 +0000
Trade Activity Log
View Count: 99
[2024-09-11 14:06:52] |
User93731 - Posts: 81 |
Hi: My Trade activity log is not opened after I click on it under "Trade" Tab. suggestion? Thanks |
[2024-09-11 15:29:25] |
Select "Window >> Reset Windows" to restore the default positions of certain windows, including the Trade Activity Log. If the Trade Activity Log was not already open, then select "Trade >> Trade Activity Log" to open it in the default position. Refer to the following: Window, CB and CW Menus: Reset Windows (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
