Date/Time: Sat, 23 Nov 2024 02:30:05 +0000
Spreadsheet Autotrade Chart - long only
View Count: 85
[2024-09-11 05:55:22]
User745789 - Posts: 313
What would be the best way to allow autotrading, but for long trades only. Context: the spreadsheet strategy can go long or short, depending on my directional bias: sometimes long only, sometimes short only, sometimes both sides.
I would rather not edit the entry and exit cells formulas each time I change directional bias. IS there another way?
[2024-09-11 14:33:30]
Sawtooth - Posts: 4118
You could use 2 cells in column H, where you manually enter 1 or 0, then reference these cells in K3/M3.
