Date/Time: Sun, 27 Sep 2026 09:53:39 +0000
[Programming Help] - Every ACSIL triggered Chart Replay throws Windows error.
View Count: 1429
[2024-09-10 17:03:03]
skalaydzhiyski - Posts: 135
Hi guys, this is the root cause of this thread -CPU Exception when Study is triggered.
I have attached the simplest possible code that triggers a replay using acsil below. When ran it throws the error below:
#include "sierrachart.h"
SCDLLName("PhitechBacktest");
SCSFExport scsf_TriggerBacktest(SCStudyInterfaceRef sc)
SCInputRef i_enabled = sc.Input[2];
if (sc.SetDefaults)
sc.GraphName = "Trigger Backtest";
sc.StudyDescription = "Phi Technologies study for Sierra.";
sc.AutoLoop = 0;
sc.GraphRegion = 0;
i_enabled.Name = "Enabled";
i_enabled.SetYesNo(true);
return;
if (not i_enabled.GetYesNo())
return;
SCDateTime start;
start.SetDateTimeYMDHMS(2024,9,9,13,0,0);
sc.StartChartReplay(sc.ChartNumber, 30.0, start);
i_enabled.SetYesNo(false);
ERROR:
2024-09-10 17:56:53.502 | Loading DLL: C:\SierraChart\Data\acsil-basic-concepts.dll (acsil-basic-concepts.dll). Handle: 7ff8eb150000
2024-09-10 17:56:53.504 | Loading DLL: C:\SierraChart\Data\acsil-drawing.dll (acsil-drawing.dll). Handle: 7ff90ce60000
2024-09-10 17:56:53.524 | Loading DLL: C:\SierraChart\Data\phitech-backtest.dll (phitech-backtest.dll). Handle: 7ff909cb0000
2024-09-10 17:56:53.525 | Loading DLL: C:\SierraChart\Data\phitech-helpers.dll (phitech-helpers.dll). Handle: 7ff8e8df0000
2024-09-10 17:56:53.532 | Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ff88c730000
2024-09-10 17:56:55.764 | Replay 30X: MES-202409-CME-USD[M] 5 Min | Reloading chart.
2024-09-10 17:56:56.409 | Replay 30X: MES-202409-CME-USD[M] 5 Min | Chart data loading complete.
2024-09-10 17:56:56.791 | Windows error code 0: The operation completed successfully.
2024-09-10 17:56:56.791 | Windows error code 122: The data area passed to a system call is too small. | Number times message added: 36
2024-09-10 17:56:56.799 | Windows error code 0: The operation completed successfully.
2024-09-10 17:56:56.799 | Windows error code 122: The data area passed to a system call is too small. | Number times message added: 36
2024-09-10 17:57:25.557 | Replay 30X: MES-202409-CME-USD[M] 5 Min | Back test processing: NumberOfTimesCalculateCalled (Cumulative) = 601
To be honest, this error is not impacting the functionality of my studies, i.e. functionally mu studies do exactly what i expect when running replays, but I just want to be certain this is not impacting sierra in some unknown way that would end up being detrimental to my backtests.
I am not sure if my spec has anything to do with this but here we go -> Windows 11 with Nvidia 16GB VRAM, 32 GB Ram 12 core i7 processor, SSD drive.
I'd really be interested to get to the bottom of this, so any pointers are welcome.
P.S.
It doesn't matter whether I use sc.StartChartReplay or sc.StartChartReplayNew...
Date Time Of Last Edit: 2024-09-10 17:08:47
[2024-09-11 07:50:08]
@SCE
I have been digging last night and I found this thread -> sc.StartChartReplay not working when new Chartbook opened
This is not related to my issue, but you have provided a snippet of code that uses sc.StartChartReplay() as an example of how to use it. I copied the code verbatum and it still throws the above error.
this is the code you provided:
SCSFExport scsf_ChartReplayTest(SCStudyInterfaceRef sc)
if (sc.SetDefaults)
// Set the configuration and defaults
sc.GraphName = "Chart Replay Test";
sc.GraphRegion = 0;
sc.AutoLoop = 0;
return;
if (sc.IsFullRecalculation)
sc.SetCustomStudyControlBarButtonText(ACS_BUTTON_1, "Start Replay");
// wait for a button
if (sc.MenuEventID == ACS_BUTTON_1)
// reset button to off
sc.SetCustomStudyControlBarButtonEnable(sc.MenuEventID, 0);
sc.StartChartReplay(sc.ChartNumber, 60, sc.BaseDateTimeIn[sc.ArraySize - 1] - 1 * DAYS);
This leads me to believe that maybe the error is something silly from Windows and has no impact on Sierra and I can just ignore it.
A simple Yes/No from @SCE would be perfectly satisfactory at this point.
All the best,
Spas
