Date/Time: Thu, 17 Sep 2026 15:42:16 +0000
[Locked] - Notice: Recent Versions and Order Fills Loaded in Chart | Daily Profit/Loss
View Count: 2070
| [2024-09-10 10:01:42] |
| Sierra_Chart Engineering - Posts: 24882 |
A new setting was recently added to control the number of days of order fills to load into a chart as an alternative to using a specified Date-Time. This is the Chart Setting: Chart Settings: Order Fills Number of Days to Load (Chart >> Chart Settings >> Trading menu) This was added in recent versions and has caused more issues than it resolved. It defaulted to 14 days which is essentially arbitrary. We are releasing version 2674, where this setting will now be defaulted to 372 days, and it will not apply to simulated trading. For simulated order fills, all available fills will be loaded in the chart. If you have any issues with order fills loaded in a chart or incorrect Daily Profit/Loss calculations then update to 2674 or higher. Although regarding the Daily Profit/Loss calculations, it is important to specify a Date-Time to load order fills for non-simulated trading: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Version 2674 will be out in about one hour. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-30 22:40:02
