Date/Time: Sat, 23 Nov 2024 05:46:23 +0000
User Contributed studies
View Count: 103
[2024-09-09 21:06:30] |
User708732 - Posts: 2 |
Bonjour, Je souhaite installer 2 indicateurs sur mon graphique qui se trouve dans les User Contributed Studies, mais je n'arrive pas à trouver cette fenêtre. Je n'ai que la fenêtre normal, en pièce jointe. Comment faire? |
IMG_20240909_154920_619.jpg / V - Attached On 2024-09-09 21:06:20 UTC - Size: 1.45 MB - 31 views IMG_20240909_162207_919.jpg / V - Attached On 2024-09-09 21:06:24 UTC - Size: 53.99 KB - 25 views |
[2024-09-09 21:07:14] |
From Google Translate: Hello,
I want to install 2 indicators on my chart which is in the User Contributed Studies, but I can't find this window. I only have the normal window, attached. How to do it? Follow the instructions at the following link, ignoring steps 2, 3, and 4: How to Use an Advanced Custom Study or a Study Collection: How to Use an Advanced Custom Study Provided To You For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
