Date/Time: Sat, 23 Nov 2024 05:47:10 +0000
CBOE 15 sec Delayed
View Count: 100
[2024-09-09 16:15:45] |
User753532 - Posts: 1 |
Hi, I tooked the CBOE Data feed yesterday and I have 15 sec DD on the VIX and VNX. Is this "normal" ? |
Capture d'écran 2024-09-09 181435.png / V - Attached On 2024-09-09 16:15:06 UTC - Size: 83.08 KB - 33 views Attachment Deleted. |
[2024-09-09 19:09:00] |
Yes, this is normal. The VIX data is only updated every 15 seconds. So depending on how you are interacting with the chart, you may see a static value displayed, or you may see the time increase and then reset to 0. This is all normal for this symbol due to how it updates.
