Date/Time: Sat, 23 Nov 2024 05:52:22 +0000
How to create default styles for drawings.
View Count: 115
[2024-09-09 13:41:30] |
atariaf - Posts: 6 |
Hello, I have found the documentation for changing tools and even for createing saved configurations for tools to load them. However, I haven't found anything that shows how to actually create a different configuration or even a default configuration. Is it possible to change the default style of a drawing so that I don't have to keep manually changing the style? Where is this located? There are no graphics settings for the chart drawings. There also is not a way to save a default inside the tools setting. I just need to be pointed in the right direction if this functionality exists. Thanks |
[2024-09-09 14:15:11] |
**Solved** Global Settings >> Tool Configs From there, you can choose the tool that you want to adjust. These settings are similar to the ones you would see when pulling up the Chart Drawing Properties on the chart, but making the changes there only effects the one drawing and does not save it as a default. It looks like you can set config settings directly in the configs for the drawing too. |
[2024-09-09 18:10:05] |
Refer to the following: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
