Date/Time: Sat, 23 Nov 2024 05:37:08 +0000
Numbers bars - Spacing Adjustment Value and Numbers Separator Character
View Count: 88
[2024-09-09 02:57:52] |
User273277 - Posts: 58 |
The minimum Spacing Adjustment Value of 3 does not move the values far enough to the right on my charts, and hides part of the first digit depending on the zoom level. Can this minimum be reduced to something like 0? It would also be useful for the Separator character to allow a few more options, like 5-6 spaces. |
Screenshot from 2024-09-08 22-44-38.png / V - Attached On 2024-09-09 02:50:51 UTC - Size: 6.81 KB - 26 views |
[2024-09-09 17:15:34] |
The "Spacing Adjustment Value" sets the amount of space that is between two numbers bars. Setting this to a higher level will increase the space, but you may have to then increase the bar spacing in order to view the data. The minimum can not be set any lower than 3.It would also be useful for the Separator character to allow a few more options, like 5-6 spaces.
We take all suggestions, but we can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-09 17:15:48
