Date/Time: Fri, 20 Sep 2024 00:56:49 +0000
Paid, but after restart still shows -1 days of full use Remaining-
View Count: 1020
[2014-09-02 17:09:38] |
namlem - Posts: 94 |
Hi SC team, could you please double check if everything is ok with my account. Notice: 1 days of full use Remaining. If you would like to continue full use the software and services, | 2014-09-02 06:34:59 purchase more usage time by selecting 'Help >> Add Usage Credit' on the menu. | 2014-09-02 06:34:59 Notice: 1 days of full use Remaining. If you would like to continue full use the software and services, | 2014-09-02 17:06:05 purchase more usage time by selecting 'Help >> Add Usage Credit' on the menu. | 2014-09-02 17:06:05 |
[2014-09-02 17:41:05] |
You need to restart Sierra Chart.
