Date/Time: Sat, 26 Apr 2025 09:40:33 +0000
Server PnL management Teton and AMP
View Count: 318
[2024-09-06 16:08:04]
User25311 - Posts: 33
Hello.
I configured the Server Profit/Loss management with Teton routing and AMP clearing as de documentation describes.
The service appears to be active and correct. But when the Net Loss conditions have been met, it has not been executed.
Does it work with AMP?
Thanks.
[2024-09-06 16:34:48]
John - SC Support - Posts: 39502
No, this does not work with AMP. AMP does not support this functionality at this time. Please ask AMP to support it, as you are not the only one that uses them as a broker that wants this functionality.
[2024-09-07 19:04:41]
User61168 - Posts: 441
Hi John, is there a page which documents all the server side options available across all your supported brokers. I am with Denali/Teton/IronBeam and trying to understand what server side features are available to me from Sierra Charts.
By default, they have put me on "Flatten all trades when floating equity drops to 50% of starting balance" which seems to be their standard option across all their customer accounts.
[2024-09-08 20:42:30]
Sierra_Chart Engineering - Posts: 19350
That feature must be from Ironbeam. It is not from Sierra Chart.
[2024-10-17 15:59:07]
Hi. As you requested, I asked AMP to enable this functionality. They contacted Sierrachart, and after several requests, they have said that it is not possible to activate the functionality. The reason according to AMP is Sierrachart. And what I have been told is that Sierra says that due to changes in CME data requirements ‘non-display’ - they envision winding down this features.
Can you please clarify this issue or explain if there was just a confusion.
Thank you.
[2024-10-17 22:43:20]
We cannot comment on this now.
