Date/Time: Sat, 23 Nov 2024 02:14:56 +0000
Trade Activity Log not opening
View Count: 164
[2024-09-06 15:44:17] |
User893419 - Posts: 2 |
When I click on "trade activity log" in dropdown menu or the shortcut keys the window doesn't appear.
[2024-09-06 16:23:02] |
Select "Window >> Reset Windows", then try again. Refer to the following: Window, CB and CW Menus: Reset Windows (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-18 12:51:07] |
User968896 - Posts: 2 |
When I click on "trade activity log" nothing shows up. I have Reset windows in the windows tab and updated SC.
[2024-09-18 15:01:50] |
Selecting "Window >> Reset Windows" should take care of this. If you still have an issue after doing the above, then the following is one site we found with some options on how to move a window off-screen back to a visible area. There are other websites you can use as well if you prefer: https://www.windowscentral.com/software-apps/windows-11/how-to-move-a-window-thats-off-the-screen-on-windows-11 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-18 15:08:10] |
Thank u so much! It was moved off screen somehow. alt+tab
