Date/Time: Sat, 23 Nov 2024 02:15:39 +0000
Continuous Horizontal Line at manually defined levels
View Count: 149
[2024-09-06 06:46:03] |
Yuri_T - Posts: 20 |
Hello, I want to have a line/several lines that are updated at specific time/start of the trading day, with lines remaining visible for past days, just like Horizontal line at time study. But I want the values for these lines to be entered manually by me, not defined by price or anything else at specific moment. If I do not enter values manually, they should remain equal to past day's values. Is there a way to do this? |
[2024-09-06 14:19:32] |
There is not really a way to automate the process such that if you do not enter values the previous lines continue. You might be able to create a custom study to do that. Refer to the following for this: Advanced Custom Study Interface and Language (ACSIL) https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php But, apart from the above, the study called "Trading Levels - Local Data" should give you what you are looking for. Refer to the following: Trading Levels - Local Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-06 18:42:04] |
ForgivingComputers.com - Posts: 960 |
The Horizontal Lines Study will do this. |
[2024-09-07 18:58:14] |
User61168 - Posts: 403 |
also possible with Spreadsheet formula study with line as subgraph draw style (until intersection if you prefer) and if you want to reset lines at specific time or multiple times during the day/session. if you are not aware of Spreadsheet Formula study, it's the holy grail of all kinds of possibilities including implementing advanced techniques for risk mgmt, money mgmt, trade mgmt, etc with excel like simple formulas.
Date Time Of Last Edit: 2024-09-07 18:58:54
[2024-09-17 06:52:24] |
I have found the way, guys. Horizontal Line at Time study - enter opening time. Then Study Subgraph Add/Subtract linked to this line - enter necessary number of ticks. Works almost exactly as I want it to. Or better else, I decided to use the Daily OHLC lines as the reference points for Study Subgraph Add/Subtract studies. Thanks to all of you anyways! Date Time Of Last Edit: 2024-09-17 07:48:48
