Date/Time: Mon, 21 Apr 2025 04:44:13 +0000
Question on how to use ice berg order for teton
View Count: 569
[2024-09-05 22:01:52]
Taverasb550 - Posts: 10
So basically I would just put for example show quantity 30 and place all my limit orders at different prices ?
Iceberg Orders Supported: Yes.
Sierra Chart Teton Futures Order Routing: What is Included
Iceberg Orders are supported through the Maximum Show Quantity setting on the A tab of the Trade Window.
[2024-09-06 13:51:00]
John - SC Support - Posts: 39362
You would put the "Show Quantity" as the value you want to show on the market and then enter the order as you want. There is no particular reason to put orders at different prices, unless that is what you are wanting to do.
[2025-03-11 01:18:08]
eddiep - Posts: 8
In this case, let's say I want to open 30 lots on ES. But, I only want the market to show 10 lots.
All I have to do is go to Trade Window tab A "Maximum Show Quantity: 10 lots" and place a market order for 30 lots? And that's it?
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=117069
imageScreenshot 2025-03-10 201145.png / V - Attached On 2025-03-11 01:15:04 UTC - Size: 40.45 KB - 43 views
[2025-03-11 02:24:25]
Sierra_Chart Engineering - Posts: 19285
We have to check but we do not think this is supported any longer with iLink 3 with Teton order routing.
Fairly sure this is not supported.
Date Time Of Last Edit: 2025-03-11 02:24:39
[2025-03-11 08:56:19]
eddiep - Posts: 8
Thank you for your answer. But you are saying Sierra Chart doesn't support Iceberg orders anymore? If I am wrong, how can I place an Iceberg order?
[2025-03-11 22:53:47]
There is no support for orders with a different display quantity when using Teton order routing. That is not supported and will not be.
