Date/Time: Tue, 15 Sep 2026 09:03:51 +0000
New bar at session start
View Count: 1596
| [2014-09-02 17:00:57] |
| tomas262 - Posts: 163 |
Hi, it seems to me that when I use range bar (6 ticks) intraday chart the function "New bar at session start" does not work correctly. For example today chart NQ 09-14, first range bar 6 time is 00:00:31 (US CT) but I would expect that to be 00:00:00. Session time setting is: Start - 00:00:00, End Time 23:59:59 I don't use evening session I am asking this because I use also 5 min chart and on both charts I have DailyOHLC study to show OPEN price and there is a difference between those charts |
| [2014-09-02 18:08:59] |
In the case of chart bars which are not based upon a fixed amount of time, the starting time of them will be the time of the first trade. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
