Date/Time: Thu, 31 Oct 2024 10:12:48 +0000
dtc protocol
View Count: 202
[2024-09-04 19:34:26]
User511513 - Posts: 3
hi , what package i have to buy to be able to use dtc protocol to paper trade my ml scripts with DTC PROTOCOLS?
[2024-09-04 22:21:19]
John - SC Support - Posts: 35639
Any of the "Integrated" packages will allow you to work with the DTC Protocol. Refer to the following:
Description of Service Packages and Pricing: Integrated Packages
Note that we do not know what you are referring to in regards to "ml scripts", but if you are able to make the DTC Protocol work for your purposes, then that is fine.
[2024-09-13 17:25:24]
Hi, I have iqfeed as data feed to sierra charts ,do I have to use the Denali data service to be able to have access to market data using the DTC protocol?
[2024-09-13 17:31:16]
Due to exchange rules, you can not access the market data using the DTC protocol.
[2024-09-13 20:44:02]
hi , i will be able to access data snapshot and update by using this codes:
const uint16_t MARKET_DATA_UPDATE_SESSION_OPEN = 120;
  //128
  const uint16_t MARKET_DATA_UPDATE_SESSION_HIGH = 114;
  //129
  const uint16_t MARKET_DATA_UPDATE_SESSION_LOW = 115;
  //130
  const uint16_t MARKET_DATA_UPDATE_SESSION_VOLUME = 113;
  const uint16_t MARKET_DATA_UPDATE_OPEN_INTEREST = 124;
  const uint16_t MARKET_DATA_UPDATE_SESSION_SETTLEMENT = 119;
  //131
  const uint16_t MARKET_DATA_UPDATE_SESSION_NUM_TRADES = 135;
  const uint16_t MARKET_DATA_UPDATE_TRADING_SESSION_DATE = 136;
  const uint16_t MARKET_DEPTH_REQUEST = 102;
  const uint16_t MARKET_DEPTH_REJECT = 121;
  const uint16_t MARKET_DEPTH_SNAPSHOT_LEVEL = 122;
  //132
  const uint16_t MARKET_DEPTH_SNAPSHOT_LEVEL_FLOAT = 145;
  const uint16_t MARKET_DEPTH_UPDATE_LEVEL = 106;
  const uint16_t MARKET_DEPTH_UPDATE_LEVEL_FLOAT_WITH_MILLISECONDS = 140;
  const uint16_t MARKET_DEPTH_UPDATE_LEVEL_NO_TIMESTAMP = 141;
  //133
  const uint16_t MARKET_DATA_FEED_STATUS = 100;
  const uint16_t MARKET_DATA_FEED_SYMBOL_STATUS = 116;
  const uint16_t TRADING_SYMBOL_STATUS = 138;
[2024-09-16 13:32:30]
No. Market data is not accessible using the DTC Protocol due to exchange rules.
