Date/Time: Wed, 27 Nov 2024 12:22:05 +0000
Two volume profiles in trade DOM
View Count: 991
[2014-09-02 16:11:41] |
Spinoza - Posts: 62 |
I am trying to put both a session and a minute volume profile in the trade Dom as discussed in this earlier support thread ( TradeDOM question ) but the minute profile keeps reverting to a session one. The earlier thread mentions this being fixed but I think it may now be recurring. I'm using version 1182. Thank you.
[2014-09-04 18:29:03] |
There is a reason why this happens. It is to ensure the Volume by Price study settings are correct for the normal use on a Trade DOM. We do not plan to change this. We recommend using a standard chart for the Volume by Price study configuration that you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-04 18:29:46
