Date/Time: Fri, 20 Sep 2024 01:04:51 +0000
CFD NAS100 vs. CME NQ data
View Count: 1739
[2014-09-02 15:56:31] |
ripsdips - Posts: 143 |
there is obviously a difference in tick or trade data of the CFD NAS100 vs.CME NQ data. Is there a solution to this aside from using a 3rd party data feed?
[2014-09-02 16:49:30] |
Did you need real-time data for the NQ futures market?
[2014-09-02 16:52:18] |
Yes.
[2014-09-02 21:27:12] |
Therefore, you need to understand CME rules in regards to this. Refer to this section here: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
