Date/Time: Fri, 22 Nov 2024 21:22:29 +0000
re Contious Contract
View Count: 175
[2024-09-03 18:46:02] |
User360283 - Posts: 504 |
Will continuous contract preserve my chart drawings? Ifs it available with Tetom? If yes how to I set it up? |
[2024-09-04 15:23:58] |
Please answer Thanks |
[2024-09-04 21:51:17] |
John - SC Support - Posts: 36236 |
We are not understanding the question. If you are asking if you change a chart to be a "Continuous Futures Contract Chart" will the drawings still be displayed/available, then the answer is yes, nothing will occur with the drawings if you change the Continuous Futures Contract Chart option. Refer to the following to setup a chart to be a Continuous Futures Contract Chart: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-05 02:29:20] |
Will my drawing be retained when the options roll and expire?
[2024-09-05 13:52:03] |
Rollover has nothing to do with whether you are using a Continuous Contract or not. When you rollover, you are given an option to also update the symbol associated with the drawings. You will want to make sure you enable this option. Even if you forget, you can update the drawings symbol through the "Manage Chart Drawings" window. Refer to the following: Chart Drawing Tools: Manage Chart Drawings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-05 15:04:11] |
I have spent 6 hours trying to get Continuous Contracts to work and suffering through confusing documentation. I being blind in one eye makes it very difficult. Very frustrated Please I need someone to sign on to my PC set this up for me. Please Thanks |
[2024-09-05 15:49:12] |
That is not something we do. You will find a list of people/companies that can help you at the following link: Sierra Chart Personal Assistance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-05 16:43:27] |
now searching for a different chart service Tell your boss |
[2024-09-24 18:33:27] |
fixed thank
