Date/Time: Tue, 29 Sep 2026 11:09:50 +0000
Loading charts faster, independent charts?
View Count: 1332
| [2014-09-02 15:09:21] |
| peaceland - Posts: 95 |
Hi, I'm sure this is something we would all appreciate. Is there a way charts can be "independent" of one another? So that we can be loading or editing on one chart, while other charts are fully functional? It is kinda tough when you are completely locked out of all your charts when you are editing or loading something. Thank you! |
| [2014-09-02 18:19:43] |
Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
