Date/Time: Wed, 23 Sep 2026 20:58:22 +0000
Alert Audio Output Device
View Count: 442
[2024-09-03 14:58:30]
CyNickal - Posts: 4
It appears that Sierra Chart is unable to route its audio to a device that is not the default audio device on Windows 10.
Changing the device does not change where the audio is output to. It seems to stay on the default device, regardless of choice applied in the "App volume and device preferences" section in Windows 10.
I would like to have my default Windows audio device set to my headphones and then route Sierra Chart's audio through external speakers. As it stands currently, I can select for Sierra Chart to route its audio through the external speakers, but it simply doesn't do it.
Please let me know if you need any more information, or if I am missing some Sierra Chart setting. Thank you.
[2024-09-03 15:35:15]
Sierra_Chart Engineering - Posts: 24947
This is not controllable in Sierra Chart. It is controlled by the operating system.
