Date/Time: Tue, 22 Sep 2026 13:14:38 +0000
Old Sierra4.config file not working in new installation
View Count: 597
[2024-09-03 13:32:53]
Gui - Posts: 8
Hello, I followed the protocol Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
But the Sierra4.config file that I transferred is not working in the new installation, for example, the Control Bar configuration is not implemented.
Any help would be much appreciated.
Date Time Of Last Edit: 2024-09-03 14:04:30
[2024-09-03 15:25:54]
Sierra_Chart Engineering - Posts: 24931
There really should not be any problem with this. There are backups of these configuration files in your prior installation. Refer to:
Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File
And make sure you are copying the file to the new Sierra Chart installation folder.
Date Time Of Last Edit: 2024-09-03 15:26:14
