Date/Time: Tue, 07 Jul 2026 12:52:09 +0000
Control Bars - Chart
View Count: 636
[2024-09-03 12:15:28]
User98657 - Posts: 420
I see there's an option in the Window menu called Control Bars - Charts. Is there any documentation on this item? I searched the Documentation for it but didn't get any hits.
[2024-09-03 14:48:36]
Sierra_Chart Engineering - Posts: 24190
No documentation yet. This command will attach a Control Bar directly attached to an attached chart.
[2024-09-03 15:13:02]
I did play with it a bit.
It appears to attach an existing control bar to a chart, correct?
I assume the idea is that I can have CBar1 on chart #1, but have CBar2 on chart #2. Anywhere I post CBar 1, it will always be the same, but I don't have to have that CBar on every chart in the Chart Book.
This helps. Thank you.
It might be nice if we could name the Control Bars. It is a limited set, so not imperative obviously, but I think it would help.
