Date/Time: Fri, 18 Apr 2025 06:47:26 +0000
[User Discussion] - BitMEX
View Count: 486
[2024-09-02 00:10:15] |
User989530 - Posts: 34 |
I have never been able to make my BitMEX account work for Sierra, I just need to send simple buy/sell orders. Is anybody using BitMEX even though we all know there is not longer support. Regards, |
[2024-09-02 05:12:46] |
ForgivingComputers.com - Posts: 1042 |
Are you able to trade through another interface to BitMex? I know they have an app. I was able to use it several years ago, but I was living in Mexico, and I traded under my Mexican wife's name. The block US citizens.
[2024-09-03 05:31:55] |
I mean, through sierra charts
[2024-09-03 05:33:27] |
I just want to know if someone is still using BitMEX here
[2024-09-03 14:47:38] |
Sierra_Chart Engineering - Posts: 19259 |
There are not many users of the BitMex interface that Sierra Chart has and when we have time we plan to work on Coinbase integration for trading.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-03 14:47:57
[2024-09-04 06:02:06] |
Can we expect the integration in the following weeks? I have been reading about this all over the forum for years.
[2024-09-11 17:33:08] |
Support can i get an answer on post #6?
[2024-09-11 17:47:37] |
John - SC Support - Posts: 39353 |
It will definitely not be in the next few weeks. This is something that is still being considered, but no work has been done yet.
[2024-09-13 04:54:01] |
If it can be done this year i will keep using SC, if not i need to migrate. That's why i need to know. Thanks! |
[2024-09-13 14:41:04] |
We can not say when it might get done, or if at all. The only thing we can say is that at the moment, we have other priorities. We doubt this is anything we would get to in the next 3 months.
[2024-09-14 20:27:58] |
If wanted to send simple buy/sell orders using Bitmex is possible?
[2024-09-19 07:53:40] |
Or BitMEX almost has no volume in general?
[2024-09-19 08:03:07] |
We will never be able to trade on Binance with Sierra charts?
[2025-02-06 03:14:30] |
Hello Support, How's the Coinbase integration going?
[2025-02-07 04:32:38] |
Hi John, can you update the #10 post?
[2025-02-07 15:38:53] |
There are no updates to share regarding Coinbase.
[2025-03-28 02:29:56] |
Any new horizon related to crypto?
