Date/Time: Thu, 26 Sep 2024 23:30:03 +0000
Numbers Bars Data Not Displaying for Daily Chart
View Count: 109
[2024-08-31 19:15:33] |
MikeWazowski123 - Posts: 1 |
Hello, My numbers bars data works just fine on the intraday timeframe. However, when I go to the daily timeframe, everything reads 0x0. I can't get accurate delta or cumulative delta but the volume works just fine. I already tried downloading data and reloading/recalculating data, but nothing changes. https://www.sierrachart.com/image.php?Image=1725131645488.png |
[2024-08-31 19:53:17] |
Sierra_Chart Engineering - Posts: 16478 |
You cannot use the Numbers Bars study on a Historical Daily chart.
[2024-09-01 20:35:51] |
User150671 - Posts: 66 |
Work around for this is to force chart to intraday period only: Chart Settings > Bar Period > Chart Data Type > Intraday Chart Only You may need to play with the session times from there to achieve what you want to. |
[2024-09-03 15:08:07] |
Yes. Refer to: Chart Session Times: Creating Daily Bars with Custom Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
