Date/Time: Fri, 20 Sep 2024 00:57:08 +0000
DOM volume by price issue
View Count: 960
[2014-09-02 08:23:30] |
User11942 - Posts: 298 |
Hello SC, please see screenshot attached. Some volume by price bars are blue. Does it mean there are only volume data and bid/ask data missing? So far only one symbol is affected - CLV4. I tried delete and download data but it didn't help. Could you please check? Thank you. |
DOM_CL.png / V - Attached On 2014-09-02 08:21:12 UTC - Size: 110.64 KB - 351 views |
[2014-09-02 19:51:12] |
Yes, this does mean there is missing bid volume and ask volume. The source of the problem has been discovered and resolved. Open a chart for the symbol and select Edit >> Delete All Data and Download. You need to do this again now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-02 20:15:52] |
NP. Thanks a lot. Many thanks as well for reverting back code for IB market depth. Found it working fine today in 1183.
