Date/Time: Fri, 22 Nov 2024 05:32:19 +0000
Play most recent alert without audio queue
View Count: 138
[2024-08-29 23:02:27]
Bedhog - Posts: 179
Hello Team,
I would like the audio queue to play the last sound without stacking sounds in the queue. The setting wait for prior alert sound is currently set = no. Audio alerts are still queueing and not being canceled. v2667 64-bit
Thank you.
[2024-08-30 03:50:12]
Sierra_Chart Engineering - Posts: 17143
Audio alerts are never canceled. That does not happen.
And how do you come to this conclusion:
We need precise details. And still whatever the behavior is, is what it is. We cannot make this any better. But you can check your sound file and make sure it it does not have any quiet parts at the beginning or end.
[2024-10-15 22:27:03]
swork - Posts: 1
I have this issue as well.
I have the setting set as follows
'wait for prior alert sound'= No
My audio file is 0.010 seconds long. When I have T&S records come through within ms there is a very obvious delay of 0.5 seconds or so between each audio playback.
