Date/Time: Fri, 20 Sep 2024 00:37:59 +0000
spreadsheet order
View Count: 980
[2014-09-01 23:37:13] |
User021827 - Posts: 174 |
In a spreadsheet study, I have positions allowed set to 1. Why are there multiple entries at same time ? I also have spreadsheet settings of " allow multiple entries in same direction " set to no. How do I keep entry to one position then ? thanks shane |
[2014-09-02 18:32:43] |
This can happen under certain conditions. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_AutoTradeManagment.php#MaximumPositionAllowed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
