Date/Time: Sat, 19 Sep 2026 20:09:27 +0000
Free trial - Live Futures data feed
View Count: 2899
| [2014-09-01 23:03:07] |
| raja - Posts: 20 |
When a client signs up for a free trial with you what they are getting is index data only ( SC forex FXCM data } They are NOT getting Live Futures data feed real time during 2 week free trial are you not providing this ? Please guide bala iyer |
| [2014-09-01 23:32:39] |
Yes this is correct because futures data is very tightly controlled by exchanges. You can use an external service for futures data. You may be able to get a trial with one of them. Refer to this page: https://www.sierrachart.com/index.php?page=doc/data.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-09-01 23:58:12] |
| raja - Posts: 20 |
thanks if we pay US$35 per month and sign up for SC real time exchange data feed - does that fix the problem ? in other words - do we then get live real time futures data feed ? |
| [2014-09-02 00:55:33] |
No. It is not that simple. For more information, refer to this section here: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Were you interested in CME futures data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-02 00:55:45
| [2014-09-02 01:00:32] |
| raja - Posts: 20 |
Were you interested in CME futures data? Yes real time live data how to get it from you guys ? Raja |
| [2014-09-02 02:03:06] |
Do you have a futures trading account? It would be best to read this section and understand it before asking anything further: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
