Date/Time: Fri, 20 Sep 2024 03:59:27 +0000
Text Label on Tools
View Count: 1490
[2014-09-01 22:40:11] |
QnReally - Posts: 181 |
I am looking for a way to open the configuration of a tool, specifically the Extending Rectangle Tool, and be able to add a user specified text label at the left and/or right of the drawing. Would you please consider this enhancement if the functionality doesn't already exist? Also, it would be beneficial to draw a horizontal line at the midpoint of the Rectangle tool and be able to configure it as part of the same Rectangle tool. This can be used to mark a price zone on the chart that may be interesting to the trader. Thanks. |
[2014-09-16 23:19:52] |
Enhancement Request: Would it be possible to add a text label to tools such as horizontal line, horizontal ray, etc? Thanks.
[2014-09-17 07:30:22] |
Would it be possible to add a text label to tools such as horizontal line, horizontal ray, etc? Thanks. Yes, this is supported. Refer to:http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ModifyText You can also add text to rectangle drawings as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-17 07:30:34
