Date/Time: Wed, 16 Sep 2026 20:51:08 +0000
Key Labels on one line for one price
View Count: 1319
| [2014-09-01 19:31:04] |
| RobertL - Posts: 26 |
Hey Guys and Gals , Was wondering if it is possible to do what I am trying to explain on the screenshot/ Create an extended string of labels at one price , so when the mkt moves, during trading hours the labels will not be covered up do to the dynamics of the hierarchy of studies. Example - have labels IBLo, DayLo, ovvpoc, 24hrvwap,LastweeksLow , etc... all visible at that key price. As it is the labels get covered up and can miss key information. Thanks, Robby |
Private File |
| [2014-09-01 19:54:59] |
| User64662 - Posts: 15 |
Move labels to left side instead of right side. Or move candles or bar back. I hope that helps I didn't see screen shot. |
| [2014-09-01 20:54:21] |
Thanks Yeah, I made the screenshot private cause I have some stuff on there didn't want to advertise |
| [2014-09-01 22:58:39] |
This is not supported other than changing the Horizontal Alignment of each Label to be different from the others.
| [2014-09-01 23:50:55] |
Ok, thanks for the quick response
