Date/Time: Wed, 27 Nov 2024 03:17:44 +0000
Intraday Chart Not loading
View Count: 85
[2024-08-26 02:42:00]
User123687 - Posts: 1
When I connect to Rhythmic account with one of the prop firms that supports Sierra charts, it do not load the intraday chart. If I select historical data than it loads fine. I already read all the rhythmic issue documents posted in support section but no help. Can you please help. Thanks.
[2024-08-26 18:43:36]
John - SC Support - Posts: 36309
Make sure you have the correct symbols for Rithmic. They are of the format ES?##.CME for the ES for example. Where ? is the contract month and ## is the two digit year. If your symbols are not correct, then open your chartbooks and select "Edit >> Translate Symbols to Current Service". Refer to the following:
Edit Menu: Edit >> Translate Symbols To Current Service
If the above is not the issue, then we would need to see your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
