Date/Time: Fri, 20 Sep 2024 00:07:08 +0000
Market statistics symbols - possibly a user discussion
View Count: 1751
[2014-09-01 17:13:04] |
User11942 - Posts: 298 |
Hello, I'm just getting confused a bit. What would be SC’s equivalents for the following IQFeed symbols: JI1T.Z DOW JONES INDU NET ISSUES JI5T.Z NASDAQ 100 NET ISSUES JI6T.Z S&P 500 ISSUES NET ISSUES JT1T.Z DOW JONES INDU NET TICK JT5T.Z NASDAQ 100 NET TICK JT6T.Z S&P 500 ISSUES NET TICK A reply from SC support or anyone else with knowledge would be highly appreciated. Thank you. Date Time Of Last Edit: 2014-09-01 17:27:14
[2014-09-01 18:02:55] |
You can find the symbols on this page here: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
