Date/Time: Fri, 20 Sep 2024 00:55:57 +0000
Feature request - ASCIL control of Horizontal Grid Line Increment
View Count: 1039
[2014-09-01 16:22:37] |
T44 - Posts: 363 |
The Scale button on the "F5" Chart Settings window launches a window which gives option for Horizontal Grid Line Increment. Can you please expose this variable to ASCIL? |
[2014-09-03 05:09:28] |
This will be added if it is not already there.
