Date/Time: Fri, 22 Nov 2024 07:53:07 +0000
"Show Menu" option not working with version 971
View Count: 2020
[2013-05-08 13:25:33] |
User30668 - Posts: 108 |
Dear SC Support Today I upgraded SC from version 963 to version 971. It seems everything is working well except for the option "Show Menu" - I can't hide the Menu Bar on my charts. I tried checking and unchecking this option but it didn't work out. It is working fine with the other options (Show Scrollbar, Show Title Bar) but not with the "Show Menu" option. Could you please take a look at it when you have time? Thanks in advance. Rui Date Time Of Last Edit: 2013-05-08 13:26:46
[2013-05-08 13:34:21] |
ganz - Posts: 1048 |
hi Version 967 "Show Menu" gd lck |
[2013-05-08 13:42:47] |
Ok, I have my answer. I hope the Support can figure out a way to have it back as it is a very useful feature. ganz, thank you for your reply. |
[2013-05-08 16:59:24] |
Support for Chart >> Show Menu will be out in the next release.
